Do ALL 2001 Camaros have LS6 intake????
The casting numbers for the LS6 design are 12573572 and 12561184 which is stamped on the manifold. The LS1 is 12560688.
Another benefit of the 2001/2002 model years is they got rid of the EGR with the LS6 intake.
Restricted User
Honestly if you got a 98-02 ls1 camaro and than just did the ls6 swap you would have a faster car because 98-00 had bigger cams. I just did the ls6 intake swap and its pretty easy, as long as you don't loose a intake man bolt
Fast intakes do not have carb numbers.....do they?
And I know about the EGR. I am looking at a car out of state that is at a toyota dealership so their LS1 terminology and knowledge is not on par with ours
BTW, I heard all 2001s have the ls6 intake from a good source.
Yes, the 2001/2002 LS1's will have the LS6 intake but I can't say for certain about the early production 01 models though. There is only a 5-7HP difference between the intakes, and the 01/02 LS1's had a milder cam. If you find a nice 99-00 you should consider it. Most of the HP gain with the LS6 intake is above 5,000 RPM.
