anyone good with electrical wiring???
Old 05-04-2010, 10:36 PM
pewter_z28's Avatar
Default anyone good with electrical wiring???
i'm not sure where to post for this..... i'm trying to figure out what this one wire is going to and what its for.
i can see it's going from the green wire on the pcm and runs to a connector under the steering column. its gotta be something aftermarket plugged into the reagular harness i would think. i know nothing about wiring
please help... lol i just want to know what purpose it serves
Attached Thumbnails anyone good with electrical wiring???-dscf2543.jpg   anyone good with electrical wiring???-dscf2544.jpg   anyone good with electrical wiring???-dscf2545.jpg
Old 05-04-2010, 11:24 PM
joshp14's Avatar
What does that box under your column have on it for markings? That might give you some insight as to what it is.
Old 05-04-2010, 11:42 PM
pewter_z28's Avatar
i'll check tomorrow and see what it has on it as far as numbers or markings of any sort. i'll post as i figure things out and hopefully find out the purpose of the wire...
thanks
Old 05-05-2010, 02:14 PM
pewter_z28's Avatar
ok i just got two numbers off of this box....
the sticker says 20 pin module connector, the blue ''unknown wire'' is feeding into the #6 pin which says.... speed/tach
theres only about 10 wires actually going into it...
supplier part number on the box 202-2154
sn 1299360 on the side of the box
thanks guys for any info
Old 05-05-2010, 02:37 PM
danbo313's Avatar
Do any of the wires go to the ignition harness? Like a heavy guage red and yellow etc?? Maybe it's a remote start module and that's the tach sense wire.
Old 05-05-2010, 02:42 PM
wisker27's Avatar
That would be for a older remote start tach learn wire. The newer remote starts did away with it.
Old 05-05-2010, 04:42 PM
pewter_z28's Avatar
beats the **** outta me i just know it leads to this connector. the car is manual everything and no remote start. but there is a thick guage RED wire that may be connected to this wire that has a fuse on it. the connector itself has pin holes for SPEED/TACH, GROUND/ ACCEL SET, +12V BATTERY, VAC VALVE, VENT VALVE, RESUME ON, DECEL SET, BRAKE/CLUTCH, VALVE POWER.. this is probably factory connector, i just seen the blue wire ran ghetto style and it seems out of place to me.
I'M 21 AND DON'T KNOW ALOT ABOUT THIS STUFF... LOL
thanks
Old 05-05-2010, 06:53 PM
danbo313's Avatar
its an aftermarket cruise control module...
Old 05-06-2010, 12:34 AM
pewter_z28's Avatar
thanks... that makes total sense to me. on the ride home from getting the car i was joking with my brother and asked if it even had cruise control, lol... since everything else was manual
Old 07-06-2010, 12:34 AM
robdave1974's Avatar
Default that wire
hey mate it is an after market cruise control unit.
i have the same unit. number 6 wire goes to the VSS (vehicle speed sensor) wire to the dash
1 ground 22 nf 3 nf 4 accel/set 5 nf 6 speed/tach 7 nf 8 nf 9 12v batt 10 12 v batt
11 vac valve 12 vent valve 13 nf 14 resume/on 15 dec/set 16 off 17 brake/clutch
18 12v brake feed 19 nf 20 valve power. nf denotes no function hope this helps
Old 01-20-2012, 11:03 AM
LeBon's Avatar
hello,
i am planning to install this module in my car, but i need the wiring diagram
can anybody upload it please?
Quick Reply: anyone good with electrical wiring???
