HELP!!!!!1999 trans am header install (time= taken a month and counting!!)
Glad to hear you found a solution and got it together.
What I don't understand is how after all the header installs on the forums, this is the first I (and many others) have heard of this issue.
sasquatch094
Trader Rating: 0
How much was the fix with the rack and pinion/steering shaft???
Trader Rating: 0
Wesmanw02
1998 Pontiac Trans Am
Wesmanw02's Avatar
Trader Rating: 2
Wesmanw02's Avatar
Trader Rating: 2
01ssreda4
01ssreda4's Avatar
Trader Rating: 48
Glad you got it fixed
01ssreda4's Avatar
Trader Rating: 48
What happened is the F41 rack that was in his car is the V6 application with less angle in the pinion- which happens to sell for ~$150.
The FE rack with the angled pinion costs ~$250. I think it's safe to assume that it failed with a previous owner and the cheaper one fit so they went with it. With the stock manifold it isn't a problem- different with headers.
https://ls1tech.com/forums/suspensio...fferences.html
