Fouling plugs on one bank of cylinders only
The truck is a 95 s10 5.3. For some reason it will run perfect up to a point then at random times when sitting in traffic or driving very slowly it will start to sputter and miss extremely badly to the point where it just wont run at all anymore and I smell a ton of unburnt gas. It will usually run fine if I drive it at light throttle but every time I accelerate hard or give it full throttle then come to a stop it will start sputtering and missing. So I changed the plugs and replaced the 02 sensors with 3 new sets and it makes no difference. It always seems to be the passenger side too. It starts to miss a little then it just gradually snowballs into a bunch of black clouds and hesitation. What do you think? Thanks
Here is the truck in question
Whip out your scan tool and post the Long Term Fuel Trims for both cylinder banks.
Then check the O2 sensor 1 for both banks while it's idling at operating temp, the mV should be bouncing around from >450mV to <450mV.
Let us know what you find.
