Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Air Intake and Exhaust Guides
- Camaro and Firebird: Header Reviews and How to Install Headers
Review and how-to
Poly Motor Mounts + Pacesetter Headers + TSP Y Install For Dummies *LOTSA PICS*
#81
Don
#82
#83
It will be a lot easier with the coils out of the way. I definately would recommend it!
You can just remove the bracket that all the coils mount to. Drivers side is a small pain with the bolt on the back of the head if I remember right.
Don
Don
#90
Great write up. I followed it and the job went smooth as silk.
I did the whole thing in about twelve hours, and thats with an ls6 intake swap.
I probibly could have done it quicker but the drinking started early.
Lesson learned, dont drink till done. But when you bust a knuckle, the drinking starts, after a few of those the knuckle busting doesnt hurt as much. lol
I also had the help of my brother, he took a side and i took a side.then helped each other when needed.
Well just wanted to say thank you for the write up.
Im gonna double check everything tommorow ans fire her up.
#91
Questions about the order of things
Thanks for the write up and additional tips and hints - I am installing kooks LTs and catted y. The job is a bear so I am addressing all the things I have access to while in there (car has 24k).
Two questions as I start reassembly. Should I replace plugs and wires before the headers or is access good enough to do it after?
I am planning on a frost tune. Should I drive it after the install is complete and let the codes set and then send out the computer or should I send it out now while the car is in the air and have everything tuned and ready as soon as the car hits the ground?
Thanks again to all - this thread is great
#92
I drove my around before I sent it out to Frost, but it did not run as good. I would just send it to him, he is pretty quick at turning them around and your car will run great when you get it back. If you have an automatic, you will freaking love the shift firmness..
Man I wish it wasn't winter right now, this is making me want to drive it :-)
I guess my only question is did you do the motor mounts too? My car had about 30,000 miles I think on it when I did my headers and one of the mounts was starting to tear..
Good Luck!!
Don
#93
Yes - I am doing motor mounts - I figure since I have it apart I am doing plugs, wires, o2s, gaskets. Everything I can get to. The process has gone well (I just jinxed it) but it will take a few more weeks since I'm only working on the weekend.
The headers are back ordered anyway - I think I will get the tune while the car is on the lift so I get the full effect of the mods from the first time I drive it.
PS - the car is M6
PS - the car is M6
#96
Tip when working alone
Doing this install currently. Since I was working alone and didn't want to wait for help - I made my own header studs to hang the gasket and header so I could get the real bolts started. I bought 2 m8x1.25 for about $2. I used my Dremel to cut off the head and cut a slit in the top to get a flat head screwdriver in (which I didn't need anyway). I threaded two into the header bolt holes, hung the gasket and fed the header through. I came to the top of the car and slipped the header over the studs and started the bolts in the four other holes. Then I backed out the studs and put the bolts in. On the passenger side I put the studs in the first two bolt holes only because I wanted to make it as easy as possible to get them out. Spreading them out a little further probably would have made the other bolts easier to start but it was still cake.
#98
I got my QTP Oval E-Cutout installed the day after we finished the MM/LT install. Just for fun, here's that video.
http://www.youtube.com/watch?v=Kl-CwUaHZHE
#99
How did you wire your cutout? What did you tap into that was 12v and where did you mount your switch. Mine is mounted above the 12v DC power output that is below the passenger cupholder. I don't want to use those wires because they are not switched (do not shut off when key is off). I tapped into a blue wire that has another wire tapped into it, but that ended up just turning my BRAKE light on and off (I guess that was for the parking brake). What wires are there that work with the ignition and are under the center console? Anyone?
I believe I spliced the red wire from behind the ASR switch, and then ground wire spliced behind the cig lighter.
If I remember whatever I used to host this writeup's pictures, I'll post a couple of those.
#100
Here we go:
That white plug I'm holding in the first picture plugs into the back of the cig lighter.
And I drilled a hole in the ash tray (gotta be careful with that because it's brittle) and mounted it in there. It's perfect and discreet, I love it!...up until my QTP Oval Cutout motor died
