installed 04+ valley cover.....retune needed?
Old 08-11-2010, 06:45 PM
cacmanjr's Avatar
Default installed 04+ valley cover.....retune needed?
I just installed the '04+ pcv valley cover and a rev xtreme catch can on my 98 LS1. Mods are listed in my signature. The car was tuned with a pcv valve in the rear of the drivers side valve cover. It seems to have lost throttle response with the new system. It also sounds very different. It appears that it is pulling much less air into the intake through the new system. When I tried to pull one of the hoses off of the catch can with the engine running, there appeared to be vacuum in the can. Can that be making the engine run rich? Is a retune necessary? All help is appreciated.
Old 08-12-2010, 06:17 PM
cacmanjr's Avatar
No one that installed the 04+ valley cover had any problems?
Old 08-12-2010, 06:24 PM
LS-1Z28's Avatar
...I installed my ls6 valley cover before tuning so I'm not much help, but if I were you I would ask whoever tuned your car.
Old 08-12-2010, 06:31 PM
cacmanjr's Avatar
Thanks for the reply. I will contact the tuner.
