Need Modding Advice!
Old 08-21-2010, 02:03 AM
19BLACKBIRD99's Avatar
Default Need Modding Advice!
Read what I have in my signature, and tell me what else I should do now, I'm getting a 9 inch rear next Monday, so I need to know what to do after that.
Old 08-21-2010, 02:07 AM
SMALLBLOCKHERO's Avatar
have the driveshaft made to fit it right.
Old 08-21-2010, 02:12 AM
What do you mean?
Old 08-21-2010, 06:35 AM
Duffster's Avatar
He means there is a chance your drive shaft will be an improper length after putting in the 9" rear end.
Old 08-21-2010, 11:52 AM
yessir.^^^ guys i know that went to a 9, their driveshafts were too long and had to be shortened.
Old 08-21-2010, 01:14 PM
On brute speed they have driveshafts you can buy along with the rear, should I do that?
Old 08-21-2010, 11:47 PM
well hell yeah, it prolly better then a stock shortened driveshaft. if you have the money...do it bro.
Old 08-22-2010, 09:28 AM
Black00Z's Avatar
Have you had it tuned?
Old 08-22-2010, 12:00 PM
garygnu's Avatar
get a cam and a tune.
Old 08-22-2010, 12:02 PM
00silver6's Avatar
when i switched to a 9in moser the drive shaft needed to be about an 1inch longer and your gonna wanna look at what yoke you have on the rear cause youll need 1350 u joints if needed. also look at your sway bar setup as if you have a stock set up it will hit the housing of your 9in and wont work well either and an adjustable panhard rod to center your rear these are things i ran into when i got mine
Old 08-22-2010, 01:12 PM
00silver6's Avatar
sorry black bird just noticed what section and what you were asking. that being said what do you plan with the car i looked at your fquick page and you have a very nice ws6 you already said you have a ms3 and ls6 heads planned.i would focus on the hook up and launch of the car getting the most out of the rear. and the rear wheel well to tire will be a little wider so there are gonna be things that are gonna come up but i would say cam and nitrous
Old 08-22-2010, 07:16 PM
im gonna run nitrous, and I wanted to get the rear so if this one ever broke I would have a 9 inch there, you know?
