Gen IV to Gen III help
Old 09-13-2010, 11:29 AM
PwrdbyLS1's Avatar
Default Gen IV to Gen III help
So I blow my 6.0L LY6(58x) this weekend, #7 has only 70psi of compression. I find a deal on a LQ9 408(24x) Gen III, my car is a 99 so I already did the conversion to Gen IV. So, I've a couple of question about returning to Gen III.
Can I reuse my LS2 timing cover with 2X gear with front cam sensor?
Can I use my LS3 valley cover with pcv system if I relocate the knock sensor on the side of the Gen 3 block.
Can I use my LY6 crank sensor on my Gen 3 block or it cannot read on a 24x wheel?
Thanks!
Old 09-13-2010, 08:27 PM
SOMbitch's Avatar
no
no
no....
Old 09-13-2010, 08:43 PM
Irish350's Avatar
why couldnt you use a gen 4 pcv setup on a gen 3 if you moved the knock sensors?
Old 09-13-2010, 08:59 PM
SOMbitch's Avatar
Well maybe you could but the gen IV valley cover will not physically mate to a gen III block.... I know you can run an LS6 PCV system with it... I had to get a gen IV valley cover when the LS2 was swapped into my car in addition to TC cover and cam position sensor extension and knock sensor extensions.......
Old 09-14-2010, 11:36 AM
PwrdbyLS1's Avatar
I have all extention harness for gen 4, so if I use a 2X cam gear, I dont why it shouldn't work.
For the valley cover, I'm more concern about the 11 holes cover versus 10 holes gen 3, and I need to plug the cam sensor hole on the block.
I supposed crank and cam sensor signal change according to the reading on the wheel or gear.
But i'm not sure... on gen 4 forum, someone answer Yes on all my question..
