Exhaust Manifold Bolt replacement part # or bolt size ?
Old 09-28-2010, 09:32 PM
ls1tech.fan's Avatar
Default Exhaust Manifold Bolt replacement part # or bolt size ?
I'm replacing the cat (passenger side) and need to replace one of the bolts (stripped where the nut comes off). Bolt is out, exhaust manifold does not seem stripped, so . .
What is the part #?
or What is the bolt size so I can replace it with something generic?
and the nut size?
Old 09-28-2010, 09:52 PM
Darkman's Avatar
http://www.dormanproducts.com/p-28717-675-567.aspx
Old 09-29-2010, 06:17 AM
Darkman's Avatar
Originally Posted by ls1tech.fan
"A" Thread Size: M6-1.0
"A" Thread Length: 13mm
"B" Thread Size: M6-1.0
"B" Thread Length: 6mm
Shoulder Length: 5mm
Overall Length: 24mm
My mistake- should be:
http://www.dormanproducts.com/p-20397-675-575.aspx
"A" Thread Size: M10-1.50
"A" Thread Length: 27mm
"B" Thread Size: M10-1.50
"B" Thread Length: 12mm
Shoulder Length: 13mm
Overall Length: 52mm
Brand: Dorman - AutoGrade - Boxed
Old 09-29-2010, 09:20 AM
The first one looks right (the other one has too large of a dead space in between)
This is for a 2000 LS1 Firebird
Old 09-29-2010, 10:41 AM
nolo200's Avatar
....or you can use M10 socket cap screws available pretty much anywhere.
Old 09-29-2010, 10:58 AM
ss2668's Avatar
The stud part # is 10220453
The nut part # is 11517996 which is (M10 x 1.5)
Old 09-29-2010, 11:31 AM
Darkman's Avatar
The dead space is larger than the OEM part, but works just fine.
Old 09-29-2010, 11:56 AM
By any chance if I find it is stripped, this one I can reach behind the exit hole and just put a stud with 2 nuts on each side. Any downside to this?
Old 09-29-2010, 12:40 PM
Darkman's Avatar
I may not understand your question correctly but if you are asking whether the stud has to be threaded into the exhaust manifold the anwer is "not necessarily."
That is to say - you could simply put bolt (or stud with a nut) through the hole in the exhaust mainfold the hole in the cat flange and secure it with another nut. The only potential pitfall might be whether there is clearance on the exhaust manifold side to accomodate a bolt head or nut. You might also want to drill out the stripped threads to accomodate a full size bolt or stud.
Old 09-29-2010, 12:48 PM
Thanks for the info (exactly what I'm talking about)
What do you mean by full size bolt? using a smaller diameter one would cause issue (not up to strength)?
Old 09-29-2010, 03:35 PM
Darkman's Avatar
Yes, I am just saying that the OEM bolt a 10mm which is larger (and stronger) than whatever bolt you would have to use to fit inside the stripped threads. On the other hand, this is just exhaust plumbing....
Old 06-21-2012, 12:29 AM
SF 1HOTLS1's Avatar
the correct bolt size is not a 1.50. the correct size is a M8-1.25 X 25MM OR 20MM. I see a lot of people saying on here its 1.50. im just tryna clear things up. that size can be bought at OSH in a flange style bolt and works great.
Old 09-07-2022, 12:46 PM
Joshua Norman's Avatar
What is the part #?
and the nut size?
10 mm
Old 09-07-2022, 01:02 PM
Received 3,025 Likes on 2,356 Posts
Originally Posted by Joshua Norman
10 mm
I bet he found that out within the past 12 years since he posted about it....
Quick Reply: Exhaust Manifold Bolt replacement part # or bolt size ?
