LS1 to LS3 MAP adapter?
Old 10-07-2010, 06:59 PM
NBMZ/28's Avatar
Default LS1 to LS3 MAP adapter?
I bought the Casper's MAP extension for my LS3 intake but it doesn't fit the MAP. Does anyone have the correct p/n for this piece so I can run this intake?
Old 10-08-2010, 04:03 PM
NBMZ/28's Avatar
Anyone?
Old 10-08-2010, 07:24 PM
Unertl42's Avatar
the LS3 MAP is different the the Ls1/2/6. You can use your original LS1 MAP sensor, but you'll have to put a larger o-ring so it'll seal, since the LS3 has a larger hole. Also, the internals on the LS3 MAP are different, that is why it won't plug in. So, you'll need a LS1/2/6 MAP sensor, and an o-ring to seal it. Hope this helps.
Old 10-09-2010, 07:17 PM
NBMZ/28's Avatar
Thanks for the help! I'll do that!
Quick Reply: LS1 to LS3 MAP adapter?
