few little extras to the car over winter
Old 10-29-2010, 09:33 PM
khoward8509's Avatar
Default few little extras to the car over winter
im looking into doing a little extra to my car this winter i am thinking about getting a ported throttle body and a 85 mm maf sensor wondering what everyone thinks of that the car has heads and cam on it and i need to get it retuned anyways so i thought with those 2 things and the tune i should pick up about 15 hps any info would be nice also wondering what everyone thinks about pulleys as well(underdrive overdrive)
Old 10-30-2010, 10:28 PM
Captain Double Post
BOBS99SS's Avatar
Keep your stock maf,unless your making big power you can't beat the stocker,I was told by a lot of people to leave it alone,maybe go with ported ends but I would research a lot on the maf ,your tuner will thank you,and p&p your stock tb is pretty easy I would say do it yourself, its not worth it to spend 100 to 150 dollars to have someone do it for you to pick up 2 to 3 hp,I can tell you some pretty easy steps to do it, or if you live in northern ohio I could do it for you,I don't know what kind of setup your running but if you have decent heads and a pretty good cam I would say a fast setup would net you the best gains, would buy it used though they get pricey,
Old 10-30-2010, 10:37 PM
Captain Double Post
BOBS99SS's Avatar
But if your just looking to do something small on the induction side p&p stock tb is a easy mod,and if you don't have a cai maybe get a ssra,I think the maf,bellow etc is all good up to 500 hp,I could be wrong but when I was doing bolt ons a few people told me that. Well good luck man,and I think materials for the tb only cost me 30 and I spent about 5 hours on it but I polished the outside to a mirror finish ,God bless bro
Old 10-31-2010, 08:53 AM
im running a small cam and light head work thought about getting the heads ported as well but i dont wanna dig in that far thanks for the help i have seen other posts on here about how to port the tb i think ill give that a shot over winter thanks for the help
Old 10-31-2010, 04:28 PM
Captain Double Post
BOBS99SS's Avatar
yeah and if you need lil help and some tips just pm me,and ill give ya my number,also when you do it grind the throttle stop down a lil bit so your blade opens all the way not half way,to me I think that made the biggest improvment,
Old 10-31-2010, 04:54 PM
Captain Double Post
BOBS99SS's Avatar
Old 10-31-2010, 07:42 PM
thanks for the help im going to work on it slowly over the winter times are so busy right now but i know once i start tearing it down i wont stop till its done(needs the intake gasket replaced) then i will be looking into how to port the tb ill definetely be getting ahold of you
