Vacuum With Larger Cams
Old 10-31-2010, 10:45 AM
DART505's Avatar
Cool Vacuum With Larger Cams
Curious if the T-rex and such in this size have enough vacuum for the brakes and accessories that use it?
Old 10-31-2010, 11:24 AM
ShevrolayZ28's Avatar
That's a pretty popular cam. I'd think if there were problems with vacuum, I'd have read about it on here. Of course, you can ask the fellas at TR, they're straight shooters.
Old 10-31-2010, 11:33 AM
DART505's Avatar
All the info I have come across and do not remember seeing anything.
Old 10-31-2010, 05:25 PM
Fastdriver1992's Avatar
my friend put a cam in his gto that had 10in of vacuum @ idle and he felt no change in the brake pressure
Old 10-31-2010, 05:31 PM
disc0monkey's Avatar
while it may have enough vacuum for brakes im sure you would experience rpm stuble after quick stops.
Old 10-31-2010, 08:29 PM
garygnu's Avatar
you can run a vacuum pump off the crank,or get a electric pump and a reservoir tank from summit or jegs.
Old 11-02-2010, 09:57 AM
copteezer496's Avatar
I run the tsp ms4 cam (239/242 643/609 @ 111) and I don't have any issues. That's one of the things I love the most about the LS motors, you can do a ton to them and not effect everything else.
