exhaust choice help
exhaust choice help
Hello, I have two choices in my price range for LT headers, new BBKw/y-pipe or used hooker with y-pipe.
Which has more ground clearence for a lowered T/A?
And is the 2 1/2" collecter on BBK much worse for performance than the 3" collector on the hooker.?
Thanks
Thanks
The BBK will have more clearance, and flow less if then the Hook Y-pipe if the outlet on the Hooker y-pipe is greater than 3". Otherwise there shouldn't be much difference since the BBk y-pipe outlet is 3". The BBK headers also will have better fitment to the Y-pipe.
Read this thread if you haven't already!
https://ls1tech.com/forums/generatio...cs-inside.html
