how long can rebuilt engine sit?
Old 01-09-2011, 05:45 PM
81cuttysupreme's Avatar
Default how long can rebuilt engine sit?
i have a rebuilt LS1 sitting in the garage, it has sat for about a year now. Is there anything I should do with it while waiting to put it in the car?
Old 01-10-2011, 03:33 PM
jdmotox333's Avatar
not really maybe spin it over sum if theres oil to lube the parts all i would think of but ive seen motors sat for 15 years put new gaskets and oil in and ran like a champ
Old 01-10-2011, 05:08 PM
Fast Toys Performance Parts's Avatar
You just want to make sure nothing rusts internally. It would be a good idea to circulate some oil through it and manually spin it as mentioned above to the rings don't rust to the cylinders.
Also make sure all the intake/exhaust ports are sealed off so stuff doesn't get inside and try to prevent moisture from getting at the engine.
Old 01-10-2011, 06:26 PM
jdmotox333's Avatar
yeah havin the top of the motor sealed off is a huge thing cause a friend of mine took the top of the motor off and it sat for a year out side still in the car but thought it be fine since it still had a hood on it and well it didnt turn out well
Quick Reply: how long can rebuilt engine sit?
