My harmonic balncer bolt fell out
Old 02-22-2011, 10:35 PM
ez money's Avatar
Default My harmonic balncer bolt fell out
i was on the way home from work and the bolt fell out. i did find the bolt and got it back in and babied it home. im going to local dealership and get a new bolt in the morning my question is what is the torque specs on it ?? the balancer didnt move any so i am sure it is fine... just didnt know the torque specs on it thanx in advance
Old 02-23-2011, 01:13 AM
lswon80's Avatar
Ok first off what I would do is check to see if you striped the threads,, I know I know,, you prob wouldn't be able to put the bolt back in if they were stripped.. just thinking of what these tech guys would say..
here is a nice write up.. http://bowlingss.com/LS1_How_To.htm
also I have one waiting to be put on.. I read that if you crank it on with tourqe wrench their is possibility of stripping thread out... I read something somewhere about a pulley installer but I dont know im prob going to do the whole tourqe wrech method.. hope this helps
Old 02-23-2011, 01:22 AM
I need a gauge for that
Atomic's Avatar
Its either 250ft lbs or 90lbs plus an additional 180 degrees, cant remember which. Either way, its a lot.
Old 02-23-2011, 06:18 AM
bayer-z28's Avatar
^ Use the old bolt, torque to 240 ft/lbs, then remove the old bolt. Install the new bolt and tq to 37 ft/lbs.
Old 02-23-2011, 06:48 AM
Kleeborp the Moderator™
MeentSS02's Avatar
Originally Posted by bayer-z28
^ Use the old bolt, torque to 240 ft/lbs, then remove the old bolt. Install the new bolt and tq to 37 ft/lbs and turn an additional 140 degrees.
Fixed your post for you...if you only torque it to 37 ft-lbs, you'll be looking for the bolt again after it falls back out. And just to be clear, we are talking about a stock style, torque to yield GM bolt - not the ARP equivalent.
Old 02-23-2011, 07:32 AM
Steve Gunn's Avatar
locktite
Old 02-23-2011, 08:25 AM
MeentSS02's Avatar
Originally Posted by Steve Gunn
locktite
Probably won't work since it is pretty oily in there.
