Intake manifold
same size as the bolts on the coil brackets. set the intake on the motor and with a straw measure the length of how deep each steaw goes in, subtract 1/4. make sure you use washer under each the head bolt.
https://ls1tech.com/forums/florida-c...l#post14656408
He is selling the intake with the bolts. You can probably pick it up real cheap or see if he is willing to split the bolts from the intake. Real good guy, I bought my fuel rail covers from him.
