polyurathane (spell check) mounts
Old 03-27-2011, 09:28 AM
Floorman279's Avatar
Default polyurathane (spell check) mounts
what are the advantages of gettin poly motor and tranny mounts?
Old 03-27-2011, 10:17 AM
1gt2nv's Avatar
Poly motor mounts= yes. I have them and love them. If you have long tubes they are a must!
Trans mount= bad. I've heard they can crack the tranny case. I would just keep the stock rubber tranny mount.
Old 03-27-2011, 11:05 AM
y are they a must with long tubes? what benefits do they have over oem mounts?
Old 03-27-2011, 11:17 AM
Bramlok's Avatar
Less flexing so the motor doesn't rock around as much. With LT's and stock mounts the y-pipe bangs on the floorboards on some cars. Poly mounts help reduce or eliminates it.
Old 03-27-2011, 05:29 PM
1gt2nv's Avatar
What he said. Before I got the poly motor mounts, my pacesetter ory would beat the hell out of my floorboard. After the mounts, not one bang from the y pipe!! Plus it helps get the power to the rear wheels. But they are a huge pita to install.
Old 03-28-2011, 06:30 AM
Ok thanks guys
Old 03-28-2011, 07:14 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Some header designs require it as they are a garbage design. I have Dynatechs with their Catted Y and never an issue with Stock Rubber on both the engine and trans. I did put a TQ arm relocation kit on the car and just did the Poly on the trans mount. Now I got a decent vibration from 70ish and up and now I gotta track that down and fix it. I have been told its due to the preload plate. Who knows.
With a stiffer mount, vibrations do transfer but will keep flexing down.
