Kooks 1 7/8" stepped 2" long tubes fitment?
Old 04-11-2011, 06:20 AM
69blueSS's Avatar
Default Kooks 1 7/8" stepped 2" long tubes fitment?
i have a set off kooks long tubes as stated above and am having some clearence issues with my stock k member. Has anyone ran into isssue with these long tubes and their factory k member? or is a tubular k member needed to run the larger 2" primarys?
Old 04-11-2011, 06:53 AM
LS1TECH Sponsor
GeorgeR@kooks's Avatar
Where are you having the isue? How old are the motor mounts? What kind of mounts are in the car? The more information you can provide the better. Or you can just call us at 1 704 768 2288. Thanks
Old 04-11-2011, 08:33 AM
69blueSS's Avatar
the motor mounts are brand new poly mounts, just switched out my solids. i'll send you a pm with more details
Old 04-12-2011, 02:04 AM
cowboysfan's Avatar
unless the headers were dropped or something dropped on them or car was wrecked you should not have any fitment issues!!
Old 04-12-2011, 06:36 AM
ls1curt's Avatar
I have the 1 7/8 stepped to 2" headers with the 3.5" collectors from kooks and am running a stock k member, but I have the solid spohn motor mounts. The only area that was tight getting in was getting the header to clear by the rear of the engine. The passenger side slid in with no issue, but the driverside was a real pain and took some time.
