Spiral Flow in place of intermediate pipe
Old Apr 11, 2011 | 08:38 AM
2000blackta's Avatar
Default Spiral Flow in place of intermediate pipe
I am going to replace the intermediate pipe in my exhaust set up with a spiral flow muffler or something similar (Pacesetter loong tubes, ORY, Borla cat back).
My question is should I go with a 3 inch welded in or a 3.5 inch clamped in? I could definitely see a leaking issue with the clamped 3.5 route but was wondering if I went with the welded 3 inch if it would be an issue to drop the exhaust if I ever needed to.
Any input would be greatly appreciated!
Old Apr 11, 2011 | 08:24 PM
TImmy_Jones's Avatar
I figured the 3 inch would slide right over and could be clamped...
Old Apr 11, 2011 | 08:50 PM
01redws6ta's Avatar
I welded mine at the front and used a band clamp at the rear (not alot of clearance, but enough)...3".
Old Apr 12, 2011 | 03:42 AM
ls1 1990 VN's Avatar
Why not flange both ends.
Old Apr 12, 2011 | 07:28 AM
I didn't think it would slip over since the whole system is 3" from the collectors back.
If that would work then I would definitely get the 3" and just clamp it.
Old Apr 12, 2011 | 09:04 AM
Jon@Texas-Speed's Avatar
I would weld it. Less chance of leaks and there are plenty of catbacks out there with a similar muffler in the I-pipe that don't have problems getting them in and out of the car.
Jon
