Which size catylic converter is correct
My 2000 trans am has stock exhaust. I am ordering the slp loud moth catback. One of my catylic converters is bad so I want to change both. I have a Jegs catalog and it lists different sizes for catylic converters. Different length and diameter. Any one know which is correct.
Thaks
Roman
Thaks
Roman
SLP fits to factory just fine. I have a SLP loudmouth 2 and like it, but I think the loudmouth 1 sounds better. I think the stock Y is either 2.5 or 2.75. . . And I'm sure you're way out of warranty, but FYI the cats on the 2000s were recalled.
Moderator
If it's catback then you don't need to add any more
cats.
Random Tech made high flow cats and Y once upon
a time. They flowed better than stock and not quite
as well as gutted shells when I tested them. I had
to give them away when I went to the aftermarket
K-member but they fit fine to the stock logs and K.
cats.
