Oil drip out the tail pipe.
I have a D1SC 01 Camaro and after the first run with the car after a long winter I've noticed a bit of an oil drip coming out of the tail pipe the next morning. Oil levels are good, the air filter is fresh but the oil looks to be engine oil. I'm thinking blow by, but the motor is strong and runs really good and with zero detonation. I'm quite concerned. I currently don't have a catch can in the car, is this something I should concider or do I have bigger problems then this.
Thanks for the help.
yea check the plugs, but if its dripping out of the tail pipe there should be plenty of smoke...and if you had a dead plug the pipes would still get hot enough to burn the oil to make it smoke...
Thanks everyone, it's most definitely oil, but the funny thing is that it's not burnt and the car doesn't smoke. I'll check again though. It's almost like something was dripping into the exhaust and slowly dripping out over night. The car ran great with no detonation, but that might not mean anything. I can't find a single drop of oil anyplace other then under the tail pipe, but the pipe it's self was dry when I checked. I need to do a a more thorough inspection, been to damn cold in my garage and I've been racking my brain about it. Thanks for the suggestions.
You said under the tailpipe? As in not in the tailpipe? If thats the case and the pipes are dry on the inside it might have just dripped from under the car. If the car isnt smoking when the exhaust is really good and hot then its not comming from inside the pipes as in from the engine internally. If its on the outside then it might be dripping from the engine and air is pushing it back there while driving. is the dipstick tube seated good. Had a friend with vortec blown 95 gt that would blow the dipstick tube out under boost and cause all kind of oil loss and it smoked like a freight train while oil was comming out. Pcv hose was kinked... If it runs good there cant really be a major internal problem Is my thinking on this one....
So the problem is that my Moser 12 Bolt has a leaky gasket from the top bolt and it pissed on the back of the muffler and part of the gas tank. It all acumilated on the floor directly below the muffler so the first thing I thought of was something was dripping out the exhaust. Sorry guys I should have had a closer look before posting this.
Need a diff gasket and rear end service and that should be that unless there is damage in rear end. I'm really NOT an idiot Lol
Thanks to everyone who responded, much appreciated.
I agree with you totally, before reading your post I had a closer look. Okay, so it is oil that's for sure, but I'm embarrassed to admit I mis-diagnosed the difference between gear oil and motor oil when I ran my finger through it. Ulgh,
