Vacuum Leak from EGR
Old 04-21-2011, 08:47 PM
jpn8801's Avatar
Default Vacuum Leak from EGR
I thought i would have to buy the hose going from the plenum to the EGR then to the passenger side exhaust manifold.. @ $125 that better fix the problem right?
How I came to this conclusion was people here were saying there is NO gasket that goes to that pipe to seal it. They were wrong! Their IS a gasket, its PART # 70895. I'ts a FEL-PRO #. When you remove the one 10mm nut to remove the EGR pipe from the plenum, it sits underneath the metal piece at the top were the bevel is.
I did that, started it up, Prrrrrrrrrs like a kitten
If you have a vacuum leak there, check that gasket, a $2 part is a HELL of alot better then spending $125 on miss information
just my $.02
Old 04-22-2011, 10:41 AM
JRENIGAR's Avatar
yes there is a gasket and yes its gonna leak again. When your ready to delte all that crap a rubber freeze plug for about $3 from local parts store will make a good seal to the ls1 intake. When your ready to ditch the ls1 intake the ls6 int is a nice gain.
Quick Reply: Vacuum Leak from EGR
