LT Header Guys!!! No more extensions or corvette o2s!
Old 11-22-2011, 09:17 AM
  #41
The Scammer Hammer
dr_whigham's Avatar
I take it that my #'s are correct? I already did it.
Old 11-22-2011, 10:23 AM
  #42
HVYMTL's Avatar
You switch the wires next to each other, pin 25 and 26 swap, 28 and 29 swap etc. Hope that helps
Old 11-22-2011, 10:41 AM
  #43
The Scammer Hammer
dr_whigham's Avatar
Well ****. I'm wrong then. I thought 25-28, and 26-29....
****-beans!
Old 11-22-2011, 11:19 AM
  #44
HVYMTL's Avatar
at least it's an easy task, lol... just reverse everything and start over otherwise I could see yours getting very confusing. haha
Old 11-22-2011, 11:32 AM
  #45
The Scammer Hammer
dr_whigham's Avatar
Well, good thing I marked every wire I touched.
So just swap them then?
25-26, 26-25
28-29, 29-28
65-66, 66-65
68-69, 69-68.
If ^^THAT^^ is right then I'll get out there with coffee in hand and get it done. I drive my car with it the other way. I hope I didn't screw anything up.
Thanks for the replies so far, HVYMTL.
Old 11-22-2011, 01:43 PM
  #46
genesisjoelton's Avatar
ok what about a tune do i just get my rears deleate or what
Old 11-22-2011, 02:52 PM
  #47
HVYMTL's Avatar
dr w, it's probably been in open loop this whole time, lol but it shouldn't hurt anything other than your plugs may have a healthy coat of carbon. I thought mine were pinned wrong but I just had a dead o2 on bank 2. I bet your car runs better after you're finished!!
No problem, man. Glad I could help. And genesis, you can still get the rears deleted. After the repin, your old front connectors are your rear connectors as so the PCM sees. It won't do anything other than turn on your CEL if you leave them there, though. The tune just deletes them so that having nothing in those connectors won't set a light
Old 11-22-2011, 03:45 PM
  #48
The Scammer Hammer
dr_whigham's Avatar
Well, I got it done, just like you said HVYMTL. Only took a minute this time.
FINALLY was able to go WOT with the new headers. HOLY ****!! This thing runs like a raped ape! The pull it has above 2500 is awesome!
Thanks for all those who contributed to this thread. Awesome stuff.
Old 11-22-2011, 04:53 PM
  #49
HVYMTL's Avatar
Yeah when I got my o2 situation straight and my car finally got the fuel tables to adjust right, it was like having a new engine. haha glad to hear it's working right for ya
Old 11-22-2011, 05:54 PM
  #50
The Scammer Hammer
dr_whigham's Avatar
Well, I still need to get tuned. My CEL is on b/c of the air delete... At Lear that's all I know of thus far. Frost will be hearing from me soon.
Old 04-27-2012, 01:32 PM
  #51
Minsab's Avatar
Default Awesome!
Came across this thread right after I lost an eBay auction for some O2 extensions! Wheeew never been so glad to lose an auction saved me $40 excellent write up man. Some new Pacesetter LT's will be installed on the 99 TA this weekend hope the pin swap goes well! Looks to be pretty straight forward! Thanks
Old 05-14-2012, 09:16 AM
  #52
Minsab's Avatar
I know it's an old thread but thought I would chime in again anyway. I did the pin swap when I put my new LT's on it was so simple and so effective. Thanks again for the info!
Old 05-29-2012, 11:15 AM
  #53
kc533's Avatar
Wow, what a simple yet brilliant idea. I agree w/ everyone else, this should be more prevalent among the LT guys. I'm throwing a couple codes, all related to a bad front o2
sensor, and was just about to run to the store for a new one when I stumbled on this thread. My rears are already tuned out too. So, out to the garage I go....
Old 07-12-2012, 05:15 PM
  #54
The Scammer Hammer
dr_whigham's Avatar
Bumping this to the top with all the new header questions we've had on the board lately.
I ******* love the guy that discovered this and saved me good money. I bought good beer with that good money.
Old 07-13-2012, 09:11 AM
  #55
idle's Avatar
And I just found this... Definitely not buying extensions OR corvette O2's!
Old 07-13-2012, 02:38 PM
  #56
hiram007's Avatar
This is a sweet *** write up, thanks man
Old 07-23-2012, 01:17 PM
  #57
93z383's Avatar
So by doing this, you are turning the rear 02's into the fronts, and it's the fronts that you delete and tune out correct?
So everything is the same, you still get a tune to delete the rear 02's, but the rears just read as the fronts now that the pins are switched right?
I always thought the rear 02's were different, everyone was saying the rears were different sensors and weren't capable of reading everything the fronts were.. hmm they were wrong lol
If this is true and works on my 97 z28 I'm about to cancel the order for the 02 extensions I just bought! I'm a wiring noob and it looks complicated, is it really that easy?
Old 07-25-2012, 04:52 PM
  #58
Vexzer's Avatar
The thread is about not having to buy cable extensions. NB02's are all the same technology although some are electrically preheated for faster warm up. For what it's worth, Wide Bands operate differently and are not interchangeable.
Old 07-27-2012, 12:01 AM
  #59
93z383's Avatar
Ohhh wait a second, so do you still use the front 02 sensors themselves only pinned to the rear? I misunderstood I was under the impression the rear 02s became the fronts but now I get it, you're just changing it around so you can plug the front 02's into the rear harnesses and they work the same.
My bad, glad I realized that before I attempted it Headers going in tomorrow!
Can't
fuggin
wait
new Pacesetter ceramic LT's
new Pacesetter 3"ORY
new Borla catback
new GM opti
new MSD wires
new NGK tr55 plugs
EGR, AIR, AC delete
Dyno tune
She should be running like a champ after this
Huge thanks to the guy who thought of this simple yet excellent idea, now I get to put another 50 bucks towards my dyno tune instead of 02 extensions.
Old 11-29-2012, 08:48 PM
  #60
LilJayV10's Avatar
The biggest question I have about doing this is, do the 02's switch faster like they should compared running the long corvette 02's?
I know that 02's switch slower in headers but I didn't know if it was because of the lack of heat or the long *** wire going to the sensor.
Thanks.
Quick Reply: LT Header Guys!!! No more extensions or corvette o2s!
