Dual Electric Fan Wiring w/ 2003 LQ4 Harness HELP
I have a pair of Flex-a-Lite electric fans for my LQ4 408. The computer and harness is from a 2003 silverado. The fans came with a controller box that uses a probe thermostat. It sucks and is inconsistent.
My question is: how can I wire these fans to run by the PCM? I want them to run with the A/C system; turn on low speed when the a/c clutch is engaged. And I want them to run on high speed when cooling is needed. I know the 2003 trucks didn't come with electric fans, but there has to be a way to utilize the pcm's knowledge of the coolant temps, and have a signal be sent to the fans when they are needed.
PLEASE HELP
PLEASE HELP
If the computer isn't pinned for a fan out then no you can't use it to activate them. The fans would have to have their own temperature controller. If it is able to control fans, you could figure out the pins numbers and use them to power your fan relays.
