input on what high flow cat to get?
Old 06-12-2011, 10:32 PM
Z28MJ's Avatar
Default input on what high flow cat to get?
my CES light came on today for a plugged cat (stock cats) I am wondering what cat to replace them with? I thought about going the headers and ORY way but I really am not ready to go that way. I am thinking about getting Magnaflow hi-flow cats. Inputs?
Old 06-12-2011, 11:27 PM
6speedt/a's Avatar
Unless you are down on power I would wait and get headers and ORY. Then get the Cats and O2 sensors tuned out.
Old 06-12-2011, 11:34 PM
senicalj4579's Avatar
I agree.
Just save for the system you want and go ory. Get the tune and fock the cats
Old 06-13-2011, 06:33 AM
408ws6ta's Avatar
Why fix it and then replace the whole system later? Just do it once.
Old 06-13-2011, 08:37 AM
Z28MJ's Avatar
Well my reason for getting it fixed now is because I plan on doing a lot of long distance traveling and don't want a plugged cat killing my mileage. If I where to end up doing the headers and ORY how much on average does the tuning cost? work keeps cutting my hours so I am trying to plan my costs for the summer
Old 06-13-2011, 10:50 AM
6speedt/a's Avatar
Its 150 bucks thru frost....The long tubes and ory will set you back 370 for painted and 480 for coated pacesetters thru TSP. Then gaskets, plugs/wires, AIR delete, EGR delete, new GM bolts, and motor mounts about 250 bucks. so all together say 650 to be safe and about 15-30 horsepower
Old 06-13-2011, 11:34 AM
Starz T/A 17's Avatar
If your looking for the cheapest solution until you get headers I would just take the cats off and gut them and then bolt them back up.
If your worried about the CEL you can either get o2 sims for $50 or if you call local performance shops some of them will tune them out for 40-50 dollars since it takes a whole 5 minutes to do.
Old 06-13-2011, 04:04 PM
Z28MJ's Avatar
It is my DD so doing a mail tune would not work well for me. I just put new gas get and plugs and wires and such on when I redid my heads. The egr delete I could Fab up some blocks in no time, I know nothing about doing an air delete so I will have to look that up. Now the motor mounts, do I have to buy special ones or what?
Old 06-13-2011, 10:36 PM
Z28MJ's Avatar
I searched, I found the answer so ignore that
Old 06-14-2011, 06:16 AM
408ws6ta's Avatar
I plan to run the non-cats. I wish I could just not have anything, but the law is the law. lol
Old 06-15-2011, 03:15 PM
Z28MJ's Avatar
I am looking at the pacesetter LTs,
http://www.texas-speed.com/p-290-pac...e-headers.aspx
plus the pacesetter ORY, figured they would mach up well to the LTs so it would be easier
http://www.texas-speed.com/p-300-pac...ad-y-pipe.aspx
from what I have read around here, that they are alright headers. or is there better for around that price?
then all I should need is the motor mounts
Old 06-15-2011, 10:14 PM
10 Second Fun Car
jlrz28's Avatar
I have had the Random Tech and now the Magnaflow cats, both are good. Hooker Headers are around the same price.
Old 06-16-2011, 07:40 AM
SnIpEz's Avatar
LS1Tech 10 Year
I completely agree with this as well
Old 06-16-2011, 10:51 PM
Z28MJ's Avatar
haha, If I could feel a power loss I would grab the torch and cut those things off
Old 06-17-2011, 11:44 AM
bones_c's Avatar
Try ws6 store for pacesetter LT pretty sure they are cheaper there
