Fuel Pump question
Fuel Pump question
Right now I'm running completely stock fuel system other than 42lb injectors on my Trans Am. Its heads, cam, and I'm gonna be adding a FAST 102. If I go ahead and have my car tuned and I add a higher flow pump like a racetronix with the hot wire kit later will I have to have it retuned because of more fuel pressure or will I be ok ? thanks
It depends on how your fuel pressure situation is now. If you can hold 58psi at all loads then a new pump won't affect the tune. However, I highly doubt you're really holding full pressure at max fueling (WOT, High MAP, High RPM) on the stock pump with what sounds like a ~450rwhp build. In reality it's probably pulling down, perhaps several psi, and the racetronix is going to do a lot better at keeping that pressure constant. Because of that you're going to be off, and the gap will be worst at high loads when you'll be in PE (open loop) with no way to correct that difference other than re-tuning. It will send you richer, so it will be safe, but it could be off enough to cost you some power.
