A/C mounting bolts leaking oil?
Old 09-01-2011, 08:02 PM
dbeach2001's Avatar
Default A/C mounting bolts leaking oil?
I had some mods done last spring and I just noticed that oil is leaking from the A/C mounting bolts. Do the bolts need to have sealant placed on them?? Do they go all the way into the oil pan? I hired someone to do the mods, heads, cam, intake on my 01 Camaro.
Thanks.
Old 09-01-2011, 09:28 PM
Judge Smales's Avatar
is it leaking a/c compressor oil? If one of the bolts was over torqued it can crack the compressor housing and leak.
Old 09-01-2011, 11:27 PM
That's MISTER MODERATOR
Paul Bell's Avatar
HOO-BOY did I learn that lesson!
What color is the oil coming out? The holes into the block are blind-tapped. You can remove the compressor and leave these bolts out and all works fine.
Did the shop that did the work remove the A/C compressor? Even if they caused the problem, it's months later and I doubt they'll accept responsibility.
Old 09-05-2011, 10:39 AM
dbeach2001's Avatar
it appears to be engine oil. I just power washed everything to se if it is coming from above the compressor. I hope it's not the compressor. I though the mounting holes were blind taped I just wanted to make sure.
Thanks, Guys.
Old 09-05-2011, 10:56 AM
LSX Mechanic
Damian's Avatar
Compressor oil will have a green tint from the freon mixture, kinda like Predator blood.
There's no mistaking it for engine oil. If it's engine oil, somebody has made a real big boo-boo.
Quick Reply: A/C mounting bolts leaking oil?
