Gains with fast 90 and 90 throttle body over ls6?
Old 09-03-2011, 04:31 AM
Restricted User
z99ls1's Avatar
Default Gains with fast 90 and 90 throttle body over ls6?
What gains in hp should i see going from my ls6 to a fast 90 intake and throttle body? Most importantly how much should i can in the 1/4? A tenth or more?
Old 09-03-2011, 12:38 PM
Darkman's Avatar
https://ls1tech.com/forums/7248658-post10.html
Old 09-03-2011, 12:51 PM
Restricted User
z99ls1's Avatar
Originally Posted by Darkman
Thanks for the link so from that it makes is sound like I should gain 20 hp, but that doesn't really answer all my questions... I also am switching from the stock throttle body to a fast 90. And also looking for how many tenths an the 1/4 I will gain if anyone knows???
Old 09-03-2011, 10:16 PM
cookba's Avatar
i hope your getting a sweet deal on the FAST 90/90. otherwise i would hold out for a 92 or save up for the 102. regardless the HP has been posted. 1/4 is dependent on your driving skills but maybe .1-.2
Old 09-03-2011, 11:59 PM
Restricted User
z99ls1's Avatar
What would be a good deal on a fast 90 and throttle body? And as far as driving the car goes I drove bone stock on 245 tires to a 13.5@103 and it's an auto so I do drive to it's full pontential. I would be very very happy if I gained more tha 1 tenth with it.
Old 09-04-2011, 12:07 AM
HTX
HTX's Avatar
You should gain at least 1 tenth no problem.
Old 09-04-2011, 12:15 AM
Restricted User
z99ls1's Avatar
1 tenth would be ok but 2 tenths would be awesome lol
Old 09-04-2011, 12:24 AM
HioSSilver's Avatar
I just did a back to back dyno from a ported ls6 to a ported Fast 90 and picked up 13rwhp and 10 rwtq after retune. There was places in the graph where it picked up 14-15 and it carried the power longer. Was a definite difference from the sotp too.
Old 09-04-2011, 12:27 AM
Restricted User
z99ls1's Avatar
What do you the you will gain in 1/4 times?
Old 09-04-2011, 12:36 AM
HioSSilver's Avatar
I have'nt ran it yet. I just swapped them on thursday. Car is lighter than the last time I ran it and I did a couple areo mods so it won't be just the intake for track times.
Old 09-04-2011, 01:28 AM
Restricted User
z99ls1's Avatar
I want 2 tenths so bad!!! LOL
Old 09-04-2011, 07:49 AM
HioSSilver's Avatar
Typically you get - .1 per 10hp gained. Sotp is pretty good for the fast 90, I guess because it picked up in the whole rpm range. Pop the screen out of your mass air if you have'nt done it. That will get you .1
Old 09-04-2011, 04:54 PM
~ReapeR~'s Avatar
Doesnt popping the maf screen out mess up the drivability on autos? I was contemplating porting my maf, but not sure because of the screen problems.
Old 09-04-2011, 05:07 PM
Darkman's Avatar
Yep, the purpose of the screen is eliminate/reduce turbulence in the air stream to make the MAF more accurate. In many cases you will get an instant check engine light when the screen is removed.
Old 09-04-2011, 06:32 PM
Restricted User
z99ls1's Avatar
So are granetellie mafs without the screen any good>?
Old 09-04-2011, 06:54 PM
Darkman's Avatar
I do not know about the current LSX version. The only Granatelli MAF I have ever tried was for a small block Chevy and I returned it because it would not stopping causing codes- and I do not recall whether if it had a screen or not.
Old 09-04-2011, 10:05 PM
brianw401's Avatar
Sorry to hijack the thread, but why spend the money on the Fast intake for .20 sec. when you can do a nitrous kit for the same price & pick up over a second with a safe 125hp shot? Or go with gears for a lot cheaper & pick up .30-.40 sec? Plus the gears make it a lot funner to drive!
The Fast is a great product, but I've got a TPIS modified LS6 intake with a 90mm. throttle body & am making over 480whp with a stock bottom end. The intake mod only cost me $350 & my buddy gave me the 90mm. LS2 throttle body he had for his car that he totaled. I picked up 11whp over the stock LS6 intake & 78mm throttle body with the mod. If you already have a LS6 intake, it is an option you may want to consider. There are many great threads on here that go over this topic. Research it & make the decision that is best for you. Good luck!
Old 09-04-2011, 10:56 PM
Restricted User
z99ls1's Avatar
Thanks for trying to help, but problems with nitrous are
1. It will cost more than the fast 90/90 im getting.
2. I will have to refill it every 10 passes wich is like $50. So it's really not cheapper.. It's pretty exspensive..
3. It is much harder on the car and if something goes wrong can cause big failures.
4. I am wanting to get into 11's bolt-on only..
If I would get 2 tenths from the fast 90 I would be very happy and I really like the looks of the fast intakes
Old 09-05-2011, 09:10 AM
HioSSilver's Avatar
I've never seen poppong out the screen do anything but help, some cammed cars like the screen in it. But I think that has more to do with reversion.
I had a granitelli on my car and loved it, car seemed more responsive but i hhad to put a slp 85mm on with the fast 90.
Z99, I had a friend run 11.8 with decent mph (116 I think) with a bolt-on auto. He had a 4400 yank I think and kooks headers w/ory (same ones on my car), drag wheels, 3.73's, underdrive pulley and a little weight reduction should get you there.
Old 09-05-2011, 09:55 AM
Darkman's Avatar
Descreening is one those never ending subjects -
https://ls1tech.com/forums/new-ls1-o...-question.html
https://ls1tech.com/forums/new-ls1-o...ening-maf.html
https://ls1tech.com/forums/tags/descreening.html
Quick Reply: Gains with fast 90 and 90 throttle body over ls6?
