View Poll Results: ????
Yes
10
66.67%
No
5
33.33%
Voters: 15. You may not vote on this poll
Relocate my battery? Yes or no
I know how to do it, just wondering if I SHOULD do it.
I've also got a whole bunch of 1/0 and 4 AWG welding cable wire. I've been trying to sell it but no luck. Probably enough to do two battery relocations. Also, my tray is broken and I am going to be doing an amp install (stereo crapped out on me) so if I'm going to do it might as well be now.
I just keep changing my mind whether I should do this or not. My car is not a true DD, but I do like to drive it when it runs More of a weekend toy / sometimes strip / sunny/warm weather driver. I would hide the cut off switch by putting it behind my license plate or behind a spare tail light if I did this mod. (except when at the track, of course).
Honestly if you have the cable already I would do it. Just remember it will occupy interior room (which there isn't a whole lot of) and it will need to be properly vented and/or run a sealed battery type for safety reasons.
Restricted User
I was seriously thinking about it for awhile and I decided to not do it. Also you have to think about all the power your waisting going with that big long wire. It take voltage to run through the wire... Not to mention how heavy the wire is when you run it all the way through the car to the back. Not worth it IMO. Get a lightweight battery like mentioned above.
Voltage drop is dependent on voltage, length of wire, gauge of wire, and amperage draw on said circuit. If the wire is sized correctly, it will not adversely effect anything. Meaning the voltage drop would be insignificant.
Restricted User
Yes exactly and there is no way to overcome the length of wire. You can't just run a really small wire because its a long wire. Im not saying it will be a huge difference or anything. I am just saying with that long of a wire it will take more voltage to start...
Restricted User
lol. I see that as a lose lose situation though. That has to weigh like 10 lbs of extra weight added to the car with all the extra hardware. Plus you have to add more stuff to make it legal at the track.... Not worth it IMO, but what do I know I just spent almost $500 on a fast 90/90 setup lol
That's MISTER MODERATOR
Sounds like several good reasons to do it.
1/0 cable in NOT the size of a garden hose, that would be 4/0. 1/0 is the usual size to use when moving the battery to the rear. Using 1/0 wire actually exhibits less voltage drop from the trunk to the starter than the stock battery cables do. It really doesn't add as much weight as some might think. The 1/0 gauge wire only needs to get to the starter. From there to the alternator & front power center, 4 gauge is all that's ever needed.
Done correctly, this is a nice mod.
I'm not trying to get every last ounce of performance out of this car. It's not that type of project. More of just a fast cruiser with some creature comforts. I also have (or will be adding) more than enough electrical stuff and I don't think that's a good idea with a lightweight battery.
I'd do this more with the weight distribution and also if done right convenience I guess. Some stuff that needs a switched 12v source or lead can be hooked to the battery if in the interior and other stuff can be hooked to the stock junction block under the hood.
So from that, and between the tray being broken, and wanting to add an amp, then i vote yes.
