Balancer to water pump alignment issue
Old 09-13-2011, 09:33 PM
00duvall's Avatar
Default Balancer to water pump alignment issue
I have part number 12601402 ls3 balancer on a 2010 ls3 went to install water pump part number 12610169. balancer pulley is not stuck out far enough. pulleys are way off ?Do i need another water pump or can i shim the water pump ? Thanks Robert
Old 09-14-2011, 07:20 PM
S10xGN's Avatar
I don't know the numbers, but it sounds like you have a truck water pump...
Old 09-14-2011, 08:03 PM
Jontall's Avatar
12601402 ls3 balancer is for a Corvette. You to need a f-body/GTO/ or truck balancer. I can't figure-out your water pump part number, so I can't say which balancer you'll need.
Old 09-14-2011, 08:13 PM
LS1MCSS's Avatar
I believe that's an L99 water pump. They have a cam phaser which apparently requires a longer pump. I think the belt spacing is the same as a truck setup.
Quick Reply: Balancer to water pump alignment issue
