You guys ever play around w/intake filter?
Am thinking about trying a 4" diameter flat filter that mounts in the 4" intake tube, maybe. Again, 4" diameter & 1/2" approx tall section of a pleated filter section mounted in-line to eliminate one bend in my ram air set up.
It would then be more like a Viper ram air where the air is in-line to the intake opening w/an opening in the hood for air to enter. Would have to clean it more often. Wonder if it will create more of a pressure drop. Can measure it w/ tuning software to find out.
IDK, just thinking about it. What have you guys done in this area?
Yah, looked @ Spectre. You are right, they are 575 CFM, would need 2. That will require too much room. Searched & searched the net, as well. Couldn't find anything else that was better. Also, am thinking that using 1 slice of a 4" diameter pleated section of a flat filter just won't do it either. Would cause a greater pressure drop & would likely require cleaning after each drive.
Really want to find a way to do this, but, just doesn't seem likely unless we run without a filter, which is not an option.
