L92 Heads and LS3 Intake Conversion - Sensors?
Hello all,
I am curious, when swapping an LQ4 to L92 heads and LS3 intake, what changes are required to the harness and sensors. Can CPW simply make one for this. Can anyone offer assistance with which sensors I use. Thanks!
I used my LS1 MAP sensor in the intake I just put a oring I found laying around to take up the additional gap and made a mount to hold it in place. I also extended the wire. The injectors are different so you need to change the connecters. I got a conversion kit for that and it was around 40$ Adapts the LS1 to LS3. That should be it for any mods you have to do.
