How to fix leaks at new cat backs clamps?
I recently had a Magnaflow Quad tipped system #16723 installed on my 2000 WS6 by a local performance shop. The system uses the 1" wide band clamps on all it's connections. It leaks from each of these connections. You can see condensation spittout of them when the car is running as well as bronzing from where the gasses are coming out against the stainless metal.
What would be the best course of action to fix these leaks assuming it's not a tightness issue? Is there a better clamp to use that wont cost an arm and a leg a piece?
