FIPK back to LID!! (opinions/options)
I will be swapping back to a lid configuration. From research i think it will be a better option.
right now i have a h/c/i car. i have a ported fast 92 with a 95mm TB. right now I have the stock MAF and the K&N fipk (came on the car). I know for sure It's holding me back, mostly the MAF
I've got a WS6 lower air box coming.
I'm thinking of going to a FTP 104mm lid and a 4in LS7 maf.
i've seen people complain about tuning problems with the LS7 maf and a 98 pcm....not sure what to think...if it can be done or not.
other option was to do a lid, maybe even a 98mm with a 85mm truck maf. i know either combination will get me more power. but the 104/ls7 will net the best gains. im planning a stroker in the near future and dont want to re-do things if i dont have to.
i will also be dyno testing results when i swap them...
i should be close to 450...not sure. hitting the dyno soon.
so you think just go straight SD tune???
idk, i like the idea of the maf...i can always get the maf and have an SD tune as well...turn it off and on if needed...
The tuning issues everyone is having can be solved by getting a Saxon airflow straightner, essentially a MAF screen but much more flow than a stock screen. Get the full 4 inch intake tract, it cant hurt you
yeah, im doing a spectre 9705 maf housing and a LS7 maf with a pigtail. ill look into the straighteners...and you say the 98 pcm will have no problem with this maf???
sweet...found the straighteners...http://http://www.saxonpc.com/100mm-cells-for-100.html
guess ill start ordering the rest of my stuff...
so far ive got most my parts .
spectre 9705 maf housing 32 bucks shipped ebay (summit racing)
LS7 maf (15865791) 56 shipped ebay
WS6 lower air box (50 shipped)
awaiting:
104 FTP lid is in the mail (165 shipped from fast toys)
new air clips 24 shipped
3 -> 5 wire conversion harness (16 bucks)
find an air filter.
pic of some stuff:
as far as cost effective...so far im saying yes! i did this on the cheap.
most of my cost is because i never had a lid when i bought the car. so i have to get the lower air box and a lid.
tuning-seen people have luck tuning these. i have my own hptuners so i can also build a nice speed density tune as well. im excited to have 104>100>95>95 as my intake tract instead of K&N oblong filter...>75mm maf>95>95
got my lid the other day!
only problem-my maf housing is 3 15/16 and the ftp lid is 4 1/8...as per instructions im going to put either elecrical tape around the housing for a tight fit or some window/door insulation from home depot!
all i need now is a 4 inch coupler, air filter, and the pigtail.
ill be updating the thread with pictures and dyno results also!
