Fast intake and coolant crossover
Old 03-06-2012, 11:40 PM
Zmg00camaross's Avatar
Default Fast intake and coolant crossover
Just bought a 78 mm fast for a good price to replace my ls6 intake. Kinda funny guy bought it and never used it had it for 8 years and its brand new in the box so I said why not. But either way is there any other way then buying new coolant lines? Could I modify the stock lines? Also I would really like to have all 4 corners vented but just want to order what I need by tommorow. Anybody have some suggestions?
Old 03-07-2012, 07:37 AM
bump it up
Old 03-07-2012, 04:37 PM
MonmouthCtyLS7's Avatar
You can flatten out the stock ones and be fine...but for 50 bucks id do it right.
Old 03-07-2012, 05:54 PM
Havent found it for 50 bucks. But know I think i mite just go expensive and get the kup vapor system.
Old 03-07-2012, 06:57 PM
$50-60, if that's an issue just hulk smash down the ones u already have...good to go.
Old 03-07-2012, 08:38 PM
haha dont know if I want to do that. BUt I do have several hammers lol.
Old 03-07-2012, 09:50 PM
jbridwelltransam's Avatar
well I'd like to buy your ls6 if you want to sell it. when you change it.
Old 03-07-2012, 10:18 PM
I will let you know. Mite be a week just trying to gather parts so I install this fast correctly and going to port the fast myself.
Old 03-08-2012, 07:20 AM
bww3588's Avatar
What I'm doing is getting 2 ls6 style front cross over's and running a line from behind the intake around the side and connecting it to the front before it goes to the radiator.
Old 03-09-2012, 03:31 PM
NemeSS's Avatar
Dam, u been looking in my engine bay?
I got same thing but use the truck 2port crossover in rear and ls6 in front.
Connect them with brass t. Parts store rad.overflow tubing.
Problem solved.
Old 03-09-2012, 03:44 PM
NemeSS's Avatar
Op,
Just a tip for the valley plate cover and fast intake.
I took a countersink to the plate and tapped the m8 threads in block for 5\16-24.
I got the countersink allen bolts for about .20¢ each.
Not all the bolts need it. Just the ones interfering with intake body.
I spent less than 5$. And didnt pay for the fast button heads.
Done it for few other folks who bought intakes without bolts.
Can also use 5/16-24 button heads, if not countersunk bolts
Thr m8x1.25 pitch is very close to the 5/16-24.
Old 03-10-2012, 02:13 AM
Good to know. Havent decided to go with the kurt urban or rig up two crossovers.
Old 03-10-2012, 07:37 AM
AutomagicLS1's Avatar
If you want to do it on the cheap get another front crossover and reverse it on the rear heads then run a line up to the front T into the front line plumb it to your water pump or radiator
Old 03-10-2012, 08:06 AM
omarrakeen's Avatar
for 50-60$ id really do it right from the beginning...specially with a fast. since you saved some from the price it self..piece of mind is priceless.
Old 03-10-2012, 12:30 PM
NemeSS's Avatar
Rig the 2 crossovers and use the cash saved for something else. I reccomend the truck crossover in the rear because the outlet tube points up instead of laying flat like ls6. Use ls6 in front of engine. Tie it all in with 3$ brass T or Y. And 3-4$ worth of tubing and hose clamps
Mine been on for 6yr and been on different engines
In my car.
Quick Reply: Fast intake and coolant crossover
