CAI coating to reflect heat???
Old 03-15-2012, 09:11 PM
ls1charged's Avatar
Question CAI coating to reflect heat???
Anybody have any good suggestions for some good DIY coatings or wraps that i can use on my CAI piping that will reflect heat so the pipe doesnt soak up so much and looks good at the same time? Thanks
Old 03-15-2012, 09:16 PM
1989GTA's Avatar
I assume this is aluminum tubing. What I do is get a ceramic thermal barrier coating put on the inside of the tubing. The place I go to uses the same stuff they put on the top of pistons. On the outside I have them put on a black heat dispersant coating.
Old 03-15-2012, 09:26 PM
ls1charged's Avatar
yes its aluminum piping... do you need to do the inside of the pipe or is just doing the outside enough?
Old 03-16-2012, 08:24 AM
redtan's Avatar
Try reflectix insulation wrap from any major home improvement store. It's self adhesive and reflects heat away from the piping.
You don't need to do the inside, that's where you have cold air. You need to do the outside so you can prevent heat from the engine and manifolds from getting into the intake tube.
Old 03-16-2012, 08:45 PM
1989GTA's Avatar
When doing the ceramic coating method you do the inside with the ceramic thermal barrier coating. The outside black heat dispersant coating is optional.
Old 04-08-2012, 10:17 PM
ls1charged's Avatar
Where can i find said ceramic thermal barrier?
Old 04-17-2012, 08:55 PM
waderaces427's Avatar
Default Ceramic Coating
Hot Shot Performance Coatings in Davie, FL does Ceramic Coatings as well as other thermal barrier and thermal dispersant coatings.
