LS2 Belt Tensioner
LS2 Belt Tensioner
Will an LS2/3 bolt onto an LS1? Also if anyone knows how to remove the old original water pump gasket, i've tried everything even razor blades with extreme care, silicon remover, acetone, etc.
LS1 Miata swap need all the extra space up front. So far, LS2 Corvette Underdrive Pulley/Dampener, LS2 Short Pulley water pump. Next on list is to shave the stock Camaro altenator bracket by 0.760" then a custom bracket for the stock miata power steering pump.
Thanks in Advance!!!
