Corvette owners with fast 92 Help!
Old 05-14-2012, 05:17 PM
Rlncoalctd's Avatar
Default Corvette owners with fast 92 Help!
Hey guys,
I just installed the Fast 92 with the old TPIS 90mm throttle body. The issue is that hte stock bellow will not fit on that throttle body like the new ones or the ls2 throttle body.
The stock airbridge is oval on the C5 and I cannot get a piece of 4in smooth piping around it.
THe question is, whose bellow are you using and where do i get one ASAP?
Would it be bad to stick the 4in piece of silicone tubing inside hte oval part an seal it rather than putting it over it be a huge flow issue?
Old 05-14-2012, 07:01 PM
Tyrel2018's Avatar
deffinatly dont put it inside it. boil some water or just get the water really hot. put the one side of the silicon piping in the water for a little bit and then it should be expanded enough to fit over the throttle body. i have the slp smooth bellow on a 92mm throttle body it was a pain but i got it.
