Exhaust Heat coming up through emergency brake?
Ok, I'm fairly new to the world of Camaros, so I thought getting your opinions would help.
My 02 SS once warm has a good amount of heat coming up through the hand brake opening. I did have a new catalytic converter put on recently.
Is this normal to have a stream of heat coming in, or possibly a prob with the cat install, or some sort of seal gone bad?
Thanks!
Thanks!
mine gets warm too . maybe some heat tape under there, as i recall the c6z in 06 had an issue or maybe it was longer than that year with heat from under the center console.
http://www.exoticvette.com/insulation%20c6.htm
http://www.corvettegarage.com/produc...-corvette.html
Check to see if the lower shifter boot is torn. Remove the center console not to hard just remove the shift **** and the 2 or 3 bolts inside the center glove blox and pull it up youll see a rubber shift boot and if its tore it will let alot of heat through.
Also im speaking mainly for a m6 car ive never owned or messed with a a4 and couldnt speak from experiance on them
