Is the starter relay ls1 supposed to always be hot??
when I check mine after a vats bypass the test light is showing power at all times ....
do I need to wire in a toggle switch to cut power manually???
thanks
Rob
thanks
Rob
LS1Tech Premium Sponsor
Which wire are you probing? Pretty well any relay that switches the "hot" source will have a hot wire at all times. Then when it gets the signal, it completes the circuit/switch and sends that hot source through.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
That makes perfect sense..... Is it possible that I may be getting to great a voltage and burning up these relays ..... replaced several .... ultimately I get another random stall and no start issues again.
what might be the proper voltage
thanks
Rob
thanks
Rob
