Idle Air Motor
Old 06-20-2012, 11:47 AM
gMAG's Avatar
Default Idle Air Motor
AutoTap is showing me a reading of 'zero'.
The reading doesn't change, no matter where the throttle plate is.
There is an issue with stalling off of idle. There are no vacuum leaks, as far as I can tell.
Can I chalk this up to a defective idle air motor?
Does a 'zero' reading translate to no additional air?
Any other things I should check/look for?
Thanks.
Old 06-20-2012, 01:13 PM
Sladester2's Avatar
Pull the IAC valve and clean it. See if that helps
