LSX on a 2000, coolent vent tubes?
I did with a 90 degree drill when I put the heads on. But I missed my mark there is a broken bolt in there with the hole off centered. I need to pull the head get the old bolt out get it filled then re drill and tap the hole out. See why I am pissed now.
Got it figured out.
Should I disassemble this thing before install to check the seal?
When I install it, 2nd pass 50in pound torque do I keep making passes until it doesnt move? I have alwas did that with the stocker without issues please advise.
Thanks
Thanks
Originally Posted by Mustang Hat'r 2
Got it figured out.
Thanks
Thanks
You can if you want but you really don't have to, but if you do you will want to but a little silicone on the spots were they did. When you torque it down first pass 30in/lbs second pass 50in/lbs and leave it there.
