Pic request: Magnaflow 5x8 or (4x9) mufflers AFTER axle true duals setup.
I have everything but the mufflers ordered. If 5x8 mufflers will fit I want to run them.
My goal is straight through but as quiet as possible. This car is too loud for where I live.
Thanks!
Thanks!
You'll probably have rotate them for them to fit up in the channels on the L&R of the trunk stump. You might also consider checking to see if a 6" round muffler will fit good on each side, a 5" round shouldn't be a problem.
https://ls1tech.com/forums/5783697-post46.html
https://ls1tech.com/forums/12837500-post704.html
https://ls1tech.com/forums/15140476-post912.html
