?s about 25% powerbond pulley
Can this balancer cause surging or even some stalling?
I get some surge/bucking mostly 1500-1700 rpm but still get it a little all through idle-2k. Car is easy to stall out in reverse also in drive with quick throttle and release. Tried turning the set screw in tb to help idle/stalling issues but ends up to be way to much idle. Acts like cruise control. So could this all have something to do with the pulley?
Dumb question, but in all those new parts you have, is one of them a cam lol? I have the same pulley but mine as a M6 so its not a good comparison. Hard for me to tell about temps because of th edamn dummy gauge. My fans run pretty much all the time though, but I think its b/c of my chrs1313. Whatever is causing your problems I doubt it is the pulley. It may cause the car to charge a little slower but short of that and eating belts theres not much that can go wrong from one. People say that it can make the car run hotter because it turns your waterpump slower. Not sure how much truth there is in that.. good luck with it
I've been running a 25% powerbond pre, and post 4000 stall, and never had any kind of problems like those. Just the normal voltage drop at idle. The surging sounds like a cam issue. Didn't you just get a bunch of internal work done at slowhawk?
comp cam 228/232 112
Im reading temps from pcm.
I had ssra before the install so I know how my car was. Ssra is not the problem.
Yes I did. He says the surge is normal along with everything else im being picky about.
I know how you feel... lol I been screwed on a tune recently... mine was blamed because of heat lol.... so I said screw it and got my own hptuners and been learning myself... my tune now is a whole lot better now than what it was the day I picked it up from the sponsor... good luck... hope your tuner will atleast tweek your tune... mine had surging on cold starts and hanging idle too.. its not perfect but its getting there... your should drive a lot better than what its doing though...
I aint picky like that but my tune was jacked up lol... my afr was 13.9 at WOT when I got a wideband and checked lol... i knew then I threw money down the drain with that tune I got from the sponsor lol...
