ls1 to ls6 coolant tube pic does the go or stay
installing fast intake and after removing stock cooling tubes noticed this spacer/oring plug. i am going to install the ls6 style tubes and dont know if i should leave this or remove it. one on each corner of head. did a quick search w/ no luck and im trying to finish up tomorrow. thanks
my search resulted in one post saying i dont need them because the ls6 tubes come w/ orings. i know lots of you members have done this swap so what did you do. thanks.
I've actually removed the o-ring and replaced with the "coke tabs", worked fine, no leaking. But that's because I was reusing a piece and I recall the o-ring looked unusable.
I'd say if your NEW pieces have a good condition o-ring on it, you're fine to just use that. If they're not in good condition, you can replace the o-ring or replace with a "coke tab" safely. I keep a supply of coke tabs because when I get the chance, I replace my LS6 coolant crossovers with LS1 tubes
Dorman 56390. $8.49 for a pack of 4 from my local parts store.
I reused the stock LS1 tubes, cut & crimped them. Picked up the Dorman gaskets to replace the stockers, for cheap insurance. I have no experience with the LS6 tubes, however. This post is solely to offer an alternative option for finding the coolant crossover tube gasket.
