Plugs for e85 NA motor
I want to tune my now stockish ls1 for e85. Eventually I want high compression heads to take full advantage for the higher octane but that will have to wait.
Now I see many people run NGK 55 ( I think that was the plug) in most of their cars the way it is, and e85 needs a warmer plug, so ngk6 would be out of the question.
If I do a tune up here soon, would i be fine getting the 55's for running 93 and eventually e85?
If I am understanding everything correctly I am reading I should be fine just want to throw it out there incase I read something wrong.
I think I may go ahead and order the 6's with my headers for now, not to expensive to replace if I have to later. Plus its hard to say when I will get to that e85 point
Also, you care if sometime I pm you with e85 questions. Probably wont be for awhile
