Intake Gasket change now p0107 code and tcs off light on
Hello,
I recently removed and replaced the intake on my 2002 ws6 (origionally a california car)
Now I am throwing a p0107 map sensor code and my traction control off light is on. The fuses are all fine.
Is there a vaume line that could have causes this map code?
Thank you for any help.
The Scammer Hammer
You disconnected / broke a wire from the MAP sensor, or forgot to plug it in. I just went through this. I spent 12 bucks on a new MAP pigtail and soldered it in and problem solved. I had pulled one of the wires out from the connector itself.
Here's my thread on this exact code.
https://ls1tech.com/forums/generatio...-me-p0107.html
