Air injection tube..can I get rid of it?
I got the block off plates for my air injection and I was wondering where does that tube run to on the drivers side? Can I just cut it or do I have to find where it goes and then get rid of it? What did you guys do?
Thanks
Bye
Thanks
Bye
Originally Posted by SVC707
can i just remove the tubes and the hoses so i can it easier for the plugs replacements... i dont care too much to remove the whole pump and everything... just the two metal tubes and the hoses they go into... is that ok
thanks
thanks
You will have to get block off plates for the exhaust manifolds / headers. Also you may hear a whistling noise coming from behind the driver side headlight because of the pump.
I just put block-off plates at the headers, pulled the pipes and tubes, and pulled the fuse for the air pump. When its smog time, 10 minutes puts it all back in.
Jeff
Jeff
Jeff
Jeff
how come everything throws a code unless you block it?? and, does it cause the car to run any different when you do it??
and what does the air injection do? I heard it was just to warm up the cats when the car is cold. that true???
(yes I am new to this lol)
lol I've had NGK plugs floatin around since I bought the car and never got around to changin em...yeah that and ditchin EGR make engine bay A LOT cleaner looking...headers do nicely too
