fast 78 intake?
Old 11-27-2012, 03:30 PM
jt_2002_ta's Avatar
Default fast 78 intake?
Found one on Craigslist for 375 and was wondering if I would see any real gains over a ls6 intake. My car is full bolton,ms3 cam,4000 stall and 150 shot. I could sell my ls6 and almost get it for free,but would it be worth the hassle?
Old 11-27-2012, 03:34 PM
spina74's Avatar
https://ls1tech.com/forums/generatio...s6-intake.html
Old 11-28-2012, 01:22 PM
The Scammer Hammer
dr_whigham's Avatar
For 375 I'd be calling while I was warming up the car. In all seriousness, it's a better intake, easily ported, and maybe one day you'll find that dirt cheap 90mm with a cracked bottom b/c some idiot forgot the button head valley bolts.
Old 11-28-2012, 02:06 PM
thunderstruck507's Avatar
Yes, get it now. It's worth power as is, but you can port the snout out to 85mm and it will get you ridiculously close to the power of a 90mm Fast intake or like dr whigham said you might find good deal later on a top 90mm shell and can turn yours into a 90mm.
Old 11-28-2012, 02:12 PM
studderin's Avatar
no 90mm,TB. But you can put a 85MM TB on it, it only is 3 bolt remeber. I did that was a paper gasket and some epoxy on the stock Oring grove. worked great, I made the intake look stock, I posted some pics back 2005-2006 on here if you care to find them.
you can get a 85MM TB for cheap. I got a summit/PP one for free, needed some work with the IAC ported so it would work better, and the blade sticking. its a cheap Tb, no nice NW or anything, you can get them for under $200 I think.
Old 11-28-2012, 02:20 PM
studderin's Avatar
https://ls1tech.com/forums/lsx-parts...b-85mm-tb.html
Old 11-28-2012, 09:23 PM
ZDER's Avatar
Am i the only one that didnt gain really anything from a ls6 to a fast 78? ... i ported it myself im sure im not the best porter around as it was my first time ever doing it(sanded down top shell and inner shell with 4 different grits of sandpaper progressively getting finer).. but really i gained only 5rwtq and i lost .5hp, Granted it was 2 different dynos but i got a re-tune on the second dyno with pretty much same numbers. I had a pretty big vacuum leak coming from the intake manifold but i addressed it now and im running a stock PP throttle body, is there something im missing for this 20rwhp lol? my tuner said most likely because im running a stock cam and out flowing it ?
i like the overall look and id say a fast is better then a ls6 but for me it didnt do anything for you it might... for 375 id jump on it asap!
Old 11-29-2012, 08:55 AM
My car has varied as much as 20rwhp on the SAME dyno on different days (SAE corrected). Ran faster the day after putting down less HP on the dyno.
If it was tuned with a vacuum leak the tune is now incorrect and it needs to be tuned again.
The rest of your combo does come into play, even if he doesn't gain anything with the stock cam and current exhaust etc, there will be room to grow with the Fast. On that note, you could have some other restriction before the intake or in the exhaust.
Either way for $375 it is a steal. On a bad day he can get $300 for his intake, on a good day he could break even.
Old 11-29-2012, 03:16 PM
ZDER's Avatar
Hmm well I ran the car after the intake manifold and picked up .5mph but I went slower in the 1/4 I just think because I was running different tires and running out of gear I was within a .1 of my previous best on different wheels. Just worried something's wrong. I have a blacking SLP Lidn green air filter,descreened stock maf to a P&P stock TB , fast 78 (ported) stock heads/cam with crane 1.82 rockers, kooks long tubes/ catted Y too a 3in cutout. I feel everything is free flow and okay just had a vacuum leak then when the car would hunt for idle. Since then I cleaned the intake ports on the heads , ls6 valley cover and re seated the intake mani. Need to do a smoke test to verify no vacuum leaks but I'm pretty sure it's good.
Would lid/green air filter/maf/TB cause issues ?
Old 11-29-2012, 06:53 PM
jt_2002_ta's Avatar
gonna try and get this,u guys convinced me!!
Old 11-29-2012, 11:47 PM
Blk98Vert's Avatar
Yes buy it, I'm waiting for the day one pops up locally
Old 11-30-2012, 08:57 AM
If you buy it and don't use it let me know, I will buy it from you.
Old 11-30-2012, 09:29 AM
Zmg00camaross's Avatar
I went from a ls1 intake to a ls6 to a fast 78 home ported. It seems the fast just likes to rev a little easier above 6200. No dyno numbers or track numbers yet. Bought it brand new for 500 bucks guy had it 8 years and never used it. So my ls6 intake for 325 so I am not into it that much.
Old 11-30-2012, 10:12 AM
03Sssnake's Avatar
You can get an adapter for a 90 MM TB, the lower on the 78 flows the same as the 90 upper. This is a good compromise if you cannot source a 90 upper down the road. The opening is tapered for smooth transition.
http://www.ebay.com/itm/221075198433
Old 11-30-2012, 10:42 PM
badazz81z28's Avatar
For $375.....I would pass and pay a few extra $$ for a FAST 90. Think of it, youre half way to a brand new FAST 92....
You will wish you didn't settle.
Old 12-01-2012, 05:05 AM
The Scammer Hammer
dr_whigham's Avatar
Bullshit. The power to be had isn't from the throttle body opening, but from the runners themselves. He can get 350 shipped for his LS6 intake all day long, so he's out of pocket 25 bucks.
Pair that intake with a Shaner S3 TB and you have the best there is with a stock TB.
Old 12-01-2012, 11:47 AM
I agree with you to an extent...I agree, the power in these FAST intakes is MOSTLY in the runner design, but the throttle opening does play a part.
All I'm saying is why settle? The FAST 90/92 will make more power than a FAST 78.
Old 12-01-2012, 12:25 PM
The Scammer Hammer
dr_whigham's Avatar
Agreed with that statement, but man... 375 for a FAST 78? When I had a 78, about 9 months ago, I paid 550 shipped. Coming 200 out of pocket didnt really bother me. 25 bucks out of pocket? Like I said, I would have called the guy while my car was in the driveway warming up.
Old 12-01-2012, 01:20 PM
zacht's Avatar
can't believe people knocking this deal...i think its a good trade...and to not be out much money at all??? crap!!! do it man! those ported 78's dont do a whole lot worse that the 90/92's...
ive seen people on here spending more money on those professional products and weiand and bbk intakes that barely do better than an LS6...
Old 12-03-2012, 09:07 AM
So double the cost, then add $150-200 for a new throttle body for the extra couple HP the 90-92mm will get you?
a Fast 78mm for $375 is an excellent deal, and if down the road the snout is opened up to 85mm like posted in the threads linked above, you will be hard pressed to prove it is giving anything up to a 90mm version
Quick Reply: fast 78 intake?
