catch can mounting location?
would like to know where you guys have mounted your catch cans other then pass. side head. cant mount mines there since i still have egr. which i dont want to remove for california smog. pics would be great. planning on getting dual cans also.
thanks
thanks
Here's what I did
Mount it down below passenger side headlight(remove headlight), bolt by the frame rail on one of the bolts for the front crash bar. Once you know exactly where you are going to mount it use a hole saw or dremel so you can drain the cans from under the nose of the car.
http://i523.photobucket.com/albums/w...T92nw92005.jpg
http://i523.photobucket.com/albums/w...T92nw92006.jpg
http://i523.photobucket.com/albums/w...T92nw92008.jpg
